First power up, no config screen
gregory.t5
(@gregory-t5)
Just finished the assembly and powered on the printer.
I get a blue LED screen, but nothing to begin the config settings.
Have left it on for 10-15 minutes in case it needed initial boot-up time to do something.
Still nothing.
Where do I start to troubleshoot this?
Power supply seems okay, as LED screen has lit up.
LED screen is working, at least as far as lighting up.
No noises, beeps, etc...
So config is not triggering, or not getting to the LED screen for me to interact with?
Greg
Opublikowany : 10/06/2018 8:27 pm
LaPointe
(@lapointe)
French moderator and translator Moderator
Re: First power up, no config screen
Have you checked again that you didn't swap both LCD cables?
Opublikowany : 10/06/2018 8:40 pm
gregory.t5
(@gregory-t5)
I checked the stripes on the termination side when putting it together, and found they were marked on with a marker.
I didn't see the stripes on the LCD side - was thinking they'd be right up next to the connectors.
Now I realize that thinking wasn't right. Crazy thought to think those cables would be auto-striped in a horizontal way.
So maybe they were swapped there.
Swapped them on the termination side - config screen comes up now 🙂
Opublikowany : 10/06/2018 8:56 pm
