First layer starts then z calibration loop
Juan David
(@juan-david)
Membre
Hello,
I recently got a MK3 used from a friend. I've done full calibrations from the wizard and fully passes.
I set my Z axis calibration (-.970 mm) and the first layer looks great.
I go and start a print... the first layer looks great. It stops half way through the first layer and starts z calibration and does that loop continuously.
I need help please. I've tried everything. If there is more information needed... I'd be happy to provide.
Thank you!
Firmware version: 3.14.1 -8237
Publié : 25/07/2025 8:06 pm
First try a different print in case of a corrupted gcode.
Next check all connectors, this sort of thing sometimes occurs if something has shaken loose or, harder to spot, a flexing cable has a broken core.
Come back if problems persist.
Publié : 25/07/2025 11:33 pm
