First layer problems
Wokipokei
(@wokipokei)
The layer lines aren't touching the wall, I also don't know is my z is set too high.
Respondido : 08/04/2020 6:30 pm
RE: First layer problems
It’s hard to tell with that translucent filament. When you peel it off do the lines separate when you try to pull them apart ?  If so then it should go lower, it should be a sheet of plastic when removed.
Respondido : 08/04/2020 7:06 pm
Peter M
(@peter-m)
Search in the forum for the movie someone made, with very good zoom in, and good and bad settings.
Respondido : 08/04/2020 7:18 pm
Wokipokei
(@wokipokei)
@neophyl
Yes, the layer lines do separate when pulled.
Respondido : 08/04/2020 7:29 pm
Wokipokei
(@wokipokei)
Posted by: @peter-m26
Do you have the link to it? I cant find it in this fourm.
Respondido : 08/04/2020 7:31 pm
Peter M
(@peter-m)
