First layer PETG not sticking to print bed
Stránka 2 / 2
AnnieR
(@annier)
RE: First layer PETG not sticking to print bed
It might sound stupid but hairspray really helps.
Napsal : 05/03/2023 7:11 pm
No doubt about it.
Posted by: @annier
Napsal : 05/03/2023 8:25 pm
jsw
 jsw
(@jsw)
It's pretty much been confirmed that some (many? most?) of the 3d print stick-um products are either repackaged hair spray or of a very similar formula.
The hairstylist that my wife and I both use took a look-feel of Layerneer and said it is quite possibly a so-called unscented hair spray and gave the brand name of 'Rave' as one possibility.
I like Layerneer as it works very well and a bottle lasts a very long time with my rate of usage, so I will most likely continue to use it instead of trying to save a few bucks.
Posted by: @cwbullet
No doubt about it.
Posted by: @annier
Napsal : 06/03/2023 12:34 am
gilesjuk
(@gilesjuk)
I tried two different reels of PETG (both by the same brand, eSUN), very poor results. But got a reel of ERYONE today and it's amazing in comparison. What I found was the other brand just wouldn't stick well so I was unable to calibrate the Z amount properly, I couldn't tell if the nozzle was too close or too far away. The new stuff is amazing and it shows in the print, the first layer is flawless.
Napsal : 08/03/2023 9:17 pm
ogmios
(@ogmios)
Just wanted to reinforce that the soap and water does the trick, should someone hesitate.
Napsal : 14/05/2024 10:50 pm
Stránka 2 / 2
