First layer issues edges curling
I am having issues with my first level curling up on the edges. Also, if you zoom into the picture you will see that the first level isn't smooth. It is like the filiminent is making blobs?
Need help please...
Thanks
John
Opublikowany : 09/10/2024 9:57 pm
It's curling because the print sheet is dirty. The surface irregularity is because your first layer 'Z' offset is calibrated too low, too much squish, probably in an attempt to overcome the poor adhesion.
Opublikowany : 10/10/2024 1:35 am
