First layer inconsistencies and outer wall separation. MK3S
mparker2531
(@mparker2531)
I'm having issues with inconsistent lines for my first layer, and with other prints, I've noticed some separation between the outer wall and the infill. I've run the z-calibration several times and I think I have it set at a good height(-.750), I'm not having any issues with adhesion. I did a test with squares in each corner of the bed and I'm seeing the same effect for each square.
The left photo is the Prusa logo and the right is the batman one.
Napsal : 10/09/2019 2:19 am
RE: First layer inconsistencies and outer wall separation. MK3S
Your Live-Z needs to be adjusted a bit lower.
Search for Jeff's Life-Z My Way thread ... lots of good info.
Napsal : 10/09/2019 7:03 am
1 lidem se líbí
mparker2531
(@mparker2531)
These are my results from the Life adjust calibration. The second picture started is at -.750 and I adjusted to .825 about halfway through. The first photo is the second test at -.900 all the way through. It looks a lot better than my previous layers but I'm still getting some inconsistencies in the same areas.
Napsal : 11/09/2019 4:40 pm
