First Layer Callibration
surgebox
(@surgebox)
Hi there, I assembled my Prusa i3 MK3S+ over the weekend and have not progressed past the first layer calibration. I upped the Z offset in stages and the last print was at -1.2 as per the photos (available once moderated?). I was about to run another at -1.4 but cannot print anything more than a smeared line (which is pretty hard to remove). Is this likely due to clogged nozzle (still filament being exuded at beginning of calibration/test).
Any comments about the print at -1.2 would be greatly appreciated too.
Cheers
Best Answer by Diem:
Your first picture isn't clear enough to judge.  The second looks close, it might usefully go a fraction lower but you will have more problems with the dirt on your print sheet. Clean it.
There are no obvious signs of clogging in your pictures.
Opublikowany : 14/02/2022 5:57 am
surgebox
(@surgebox)
RE: First Layer Callibration
Hmm, I couldn't add links to these images in my original post.
Opublikowany : 14/02/2022 8:10 am
Opublikowany : 14/02/2022 2:28 pm
surgebox
(@surgebox)
Thanks Diem. I went to -1.3 and am really happy with the results. Noted your comments regarding cleaning print sheet.
Opublikowany : 15/02/2022 9:01 am
