First Layer Calibration every time i change the bed ?
GurSingh
(@gursingh)
I am using Texture bed for PETG and Smooth bed for PLA. Every time switch to different material also change the bed and i also need to re-Calibration my first layer. Is that expected ? i thought that you can store your first layer calibration with bed sheet you are using ?
TIA.
Best Answer by Ringarn67:
@gursingh
Here is an article about sheet profiles
https://help.prusa3d.com/en/article/steel-sheet-profiles_1955
Postato : 25/06/2021 6:15 am
Ringarn67
(@ringarn67)
RE: First Layer Calibration every time i change the bed ?
@gursingh
Prusa i3 MK3S+ FW 3.11.0 (kit dec -20), PrusaSlicer 2.6.1+win64, Fusion 360, Windows 10
Postato : 25/06/2021 6:27 am
1 persone hanno apprezzato
GurSingh
(@gursingh)
Thank you @Ringarn67, i was doing the first layer calibration from the Calibration menu ever time instead of doing from the HWSetup for the sheets/bed which was not getting saved per sheet.
Postato : 25/06/2021 6:45 am
