[Solved] First layer calibration after assembly
Edmond
(@edmond)
I can't fix the problem by adjusting the probe, adjusting Z. I have been fixing it by trial and error for many hours, it still doesn't work
Napsal : 28/12/2019 3:36 pm
RE: First layer calibration after assembly
It seems that your bed was not plane and/or not leveled (not parallel to the X and Y axes). Try tu adjust it with a steel ruler and check the parallelism to the axes with a gauge or optical (maybe also with a paper) controll of nozzle/bed distance at 9 points).
Also important is a correct Z-Level fineadjustment and a clean bed (no dust and oil..). Try to clean the bed with soap and hot water, maybe also Isopropanol. For PLA the smooth sheet is the better option.
Napsal : 30/12/2019 1:45 am
rmm200
(@rmm200)
I link this article so often I should pay a commission:
After you do this, post a picture of your calibration square (or circle).
Napsal : 30/12/2019 7:14 am
Edmond
(@edmond)
@karl-herbert
Thanks for your advice, I'm trying it.
Napsal : 11/02/2020 7:41 am
Edmond
(@edmond)
@robert-rmm200
It’s my result. What’s wrong, thanks?
Napsal : 11/02/2020 9:02 am
Edmond
(@edmond)
Posted by: @edmond
@robert-rmm200
I tried to adjust the nozzle and recal the xyz, it's the re-print result.
Napsal : 11/02/2020 10:08 am
rmm200
(@rmm200)
While it is printing, slowly lower the Z (make it more negative) until the strands blend together.
In your picture, they are like strings laid side by side.
Done correctly, they will partially merge and peel up as one surface when you are done.
Napsal : 11/02/2020 4:02 pm
1 lidem se líbí
Edmond
(@edmond)
I finally solved the problem, it is about the height of the nozzle. I tried to troubleshoot the problem by recalibrating XYZ for many times, but I failed. However, I began to have the idea of my problem, and I started to adjust the height of the nozzle, I just followed the assemble instruction to adjust it from the left corner to the right corner, and make sure the the parallelism (the x-axis and the bed).
Finally, I realise the problem is about first layer, and solve it by referring a very nice article.
3D Printing First Layers Problems
https://3dnewb.com/3d-printing-first-layer-problems/
It introduces a model to adjust your bed leveling. It is a must keep item!! really.
https://www.thingiverse.com/thing:34558  (please refer to the article for the description of testing).
Hopefully, it can also help others who also assemble by yourself. It is not a easy thing to figure out the problem by a new 3D printer joiner.
This post was modified před 6 years 2 times by Edmond
Napsal : 11/02/2020 4:09 pm
Edmond
(@edmond)
@robert-rmm200
thank you robert! your hints of height helps me a lot!
Napsal : 11/02/2020 4:11 pm
