First benchy, now with pics! Troubleshooting appreciated.
Pixel Visions
(@pixel-visions)
Reposting to correct broken pics.  I just printed my first benchy, and a second after correcting the Z adjust to get a flat bottom and test a temp reduction.  Both models have the same small issues, and one major one.  I am printing from the included SD card, and my printer was pre-assembled. Great circle on the chimney, so I don’t think any belts are loose.  Any ideas/recommendations, especially to resolve the big pits in the back on the left side of the plaque? ::sigh:: Some images got stretched on post, but you get the idea.
Admin, please delete the earlier broken post, I didn't see an option for me to delete or edit it to fix the images.
Large pits on back along seam
Blobs and distortion on archway
Zits on wheel, small pits on deck
Flat window arch, scarring on frame
Distortion on window frame
Pits on hull
This topic was modified 5 years temu by Pixel Visions
Opublikowany : 24/01/2021 2:48 am
RH_Dreambox
(@rh_dreambox)
RE: First benchy, now with pics! Troubleshooting appreciated.
The bottom of your Benchy shows that your Z level is too high.
Start by calibrating it so that you get a smooth and tight first layer and some of the problems will be fixed.
Opublikowany : 25/01/2021 8:13 am
