Filament will not load
mpkunz
(@mpkunz)
Brand new kit machine. Cannot be plugged up, never had filament in it. Filament will not feed. I cut the end on an angle, nothing happens. No error messages telling me something is wrong. Can I take this somewhere in the USA to have it worked on ?
Respondido : 29/10/2022 8:15 pm
Do you have a multimeter?  If so check the dc voltages arriving at the einsy board.
What happens when you switch on?
Do any lights glow?  Does the screen light up?
Do any fans turn?
Er, probably.  Does anyone in the US know?
As it's new you might do best contacting Prusa Support: Log into your Eshop account, navigate to Help and live chat is at bottom right in most browsers. If not you may need to disable your ad-blocker temporarily.
Respondido : 29/10/2022 11:24 pm
RandyM9
(@randym9)
RE: Filament will not load
Do you have the menu set to ‘auto-load’ the filament?
Are you pre-heating the hotend?
Have you tested the filament sensor to insure it’s reading properly?
Cheers
Respondido : 30/10/2022 4:02 am
mpkunz
(@mpkunz)
Brand new kit, its on its shakedown cruise. The self-setup software cannot complete its own setup because it cannot get past this step.
Respondido : 30/10/2022 11:24 am
Have you cut the end of the filament at 45 degrees? this helps to ease loading
Respondido : 30/10/2022 11:39 am
mpkunz
(@mpkunz)
First thing I tried.
Respondido : 30/10/2022 12:09 pm
sqlegan
(@sqlegan)
Don't know if this will help, but I've just built mine and was having similar troubles. Turned out I'd put the Bondtech cog, the one on the flap in the wrong way round
Respondido : 10/11/2022 5:56 pm
mpkunz
(@mpkunz)
That did the trick. Thanx.
Respondido : 10/11/2022 8:48 pm
