Filament not extruding
2002superhawk
(@2002superhawk)
My printer had been working great since I bought it several months ago. Last night, I went to check on a print and it had stopped extruding filament. My initial thoughts were a clog in the nozzle. I used the auto unload feature and that worked great, but when I tried to use the Load feature it doesn't pull the filament at all. The printer just  displays the "is the filament the correct color" prompt.  Is there a good place to start to diagnose exactly what is going on? (or someone in MA or southern NH who i can bring it to for repairs?)
I also noticed that the mounts surrounding the hot end were very soft from the heat (and I successfully broke one of the pieces off yay me!), so while  I am waiting for a new one it may take a few days to try things
Thanks,
James
Postato : 14/09/2019 2:14 pm
Dimensions of Three
(@dimensions-of-three)
RE: Filament not extruding
I fixed a similar issue on my own MK3S yesterday. Can you check your filament idler door/gear to see if it catches somehow... ever so slightly? That was my issue and took me weeks to find out, finally together with the Prusa troubleshooting team I found the issue.
Questo post è stato modificato 7 years fa da Dimensions of Three
Postato : 14/09/2019 2:25 pm
2002superhawk
(@2002superhawk)
thanks, i'll check that!
Postato : 14/09/2019 3:28 pm
delwilson6241@gmail.com
(@delwilson6241gmail-com)
@michel-s5
How did you isolate the problem and what was the fix?
Postato : 24/11/2019 12:47 am
2002superhawk
(@2002superhawk)
@del-wilson
It is fixed. I needed to step away from it for a day or so then realized the grub/set screw on the extruder shaft had loosened, and it was just spinning. It’s been working fine since then.
Postato : 24/11/2019 1:24 am
