failing support on first major print after assembly
ahmad.m3
(@ahmad-m3)
Hi
I recently assembled my printer and after troubleshooting some assembly issues I made my first major print that took 1 day to complete.
I created the G-code using Prusa control for Colorfabb xT at .2 mm layer height with support everywhere option.
the support was printed very poorly; here was the major issue; It zigzagged along the print length and didn't do a great job at holding the sections it was supposed to carry; those sections either lifted up due to their first layer not printing correctly into the support. check below images to better understand what I mean.
I appreciate any help; I'm contacting support but they are extremely slow to respond.
Publié : 24/09/2018 8:35 pm
ahmad.m3
(@ahmad-m3)
Re: failing support on first major print after assembly
Would anyone please help out with this issue?
Publié : 06/10/2018 7:26 pm
Raku76
(@raku76)
Is this your very first print?
How about starting with small parts first, where you can have more detailed information about what is the printer doing at each stage?
A 24h print is a high risk enterprice if you don't have your printer under control. I recommend to investigate the printer running much smaller parts. For example printing the calibration surface.
Good luck!
Publié : 06/10/2018 9:12 pm
ahmad.m3
(@ahmad-m3)
Good luck!
I actually printed the first layer calibration square and tweaked height until it was ok. my first print was the Prusa buddy and I did some tweaks until it I was coming out nice. one problem I had to solve is that X-axis belt was rubbing with the sides and I solved that by adjusting the pulley on X motor. Maybe I should run calibration test to check for X-belt tension?
Publié : 08/10/2018 11:58 am
