Fail Z Calibration
RicardoHormigos
(@ricardohormigos)
Fail Z Calibration
Hello,
I´m new on this comunity and very exiting to start to learn as fast as posible about this 3d world.
I have assy my new I3 MK3.
Everithink works except the Z calibration.
I have try many thinks following the documentation from the forum and website, reajust sensor, polleys tension, etc but always the same result.
Also I have update the fw to the last for the MK3 from the web site.
Could you please help me on this topic?
What to check? Any idea about what may cause this issue?
Thanks a lot to help me.
BR
Postato : 09/04/2018 11:38 am
RH_Dreambox
(@rh_dreambox)
Re: Fail Z Calibration
During the Z-level calibration, the upper part of the X motor holder must hit the screws holding Z-axis top parts.
If the X motor holder does not reach up to the screw heads, you have either mounted the spool holder back and forth, or you have mounted the Trapezoid nuts upside down.
Postato : 09/04/2018 2:12 pm
