Extruder idler plug
Henry
(@henry-6)
Extruder idler plug
Where does the extruder idler plug go. mine fell out and i can't see where it goes.
Postato : 11/10/2018 11:28 pm
The Plastic Shed
(@the-plastic-shed)
Re: Extruder idler plug
It fell out ? - something disconnected from the Einsy control board or is this something on the extruder itself ?
Extruder 'idler' is confusing ... have you tried looking at the build instruction in the support area ? there are some pretty good pictures there that may help. You need to select the section that has the 'idler' plug in it but if it's electrical it is section 8 off the top of my head.
edit : here is a link
https://manual.prusa3d.com/c/Original_Prusa_i3_MK3_kit_assembly
Postato : 11/10/2018 11:48 pm
Step 48 in the assembly manual for the extruder :
Postato : 12/10/2018 12:05 am
Henry
(@henry-6)
Thank you. That's where i put it but i thought it did more than that.
Postato : 12/10/2018 3:29 am
