[Résolu] Z-Axis seems too stretched
lostretrotapes
(@lostretrotapes)
Hi, I am building my first Prusa, has been going well until the end of the Z-Axis chapter (4)
I have put some images to illustrate what I am seeing, but the top parts seem to be at a very stretched angle, it was really hard to get it screwed to the frame, and I am worried they are under too much stress as most images I see they run around 90 degrees from the frame, and in mine they are on a much bigger angle. Can someone take a look and advise if they are looking correct, or what the problem might be?
The images can be seen here https://imgur.com/a/YZ6XJ8e
Ce sujet a été modifié il y a 4 years par lostretrotapes
Publié : 03/02/2022 10:45 am
Zoltan
(@zoltan)
Membre Moderator
RE: Z-Axis seems too stretched
CAn you please attach the pictures here? People do not like to go to servers they do not know anything about them
Publié : 04/02/2022 10:26 am
JimB
 JimB
(@jimb)
Unless it is a weird camera angle, those top pieces do look malformed or bent  The back and outside edge should form a 90 degree angle (joined by a 45 degree).  You can see that parts at https://www.prusaprinters.org/prints/57217-i3-mk3s-printable-parts/files (z-axis-top.stl).  I can't tell if the bottom of the z-axis is right from you pictures.  All 4 of those vertical rods should be straight up and down.  I wonder if you got the x-axis rods fully inserted or if you used the wrong rods someplace.
Publié : 04/02/2022 5:06 pm
a_patch
(@a_patch)
This side looks fine, but maybe on the other metal rods are not fully pushed in? That can cause gantry to be "too wide", and then stretch those parts?
Publié : 11/02/2022 4:15 pm
