Dragging, uneven 1st layer print
skaddisbladis
(@skaddisbladis)
Hello, I calibrated my printer so many times and the quality of the test calibration test is very good!
Still I face several issues:
1. The upper part of platter for some reason always has transparent look and is very thin.
2. Dragging effect happens
3 Sometimes because of that the first layer has some unfinished edges.
Thank you for reading, I look forward to your expertise.
Respondido : 21/02/2023 6:20 am
Robin
(@robin)
RE: Dragging, uneven 1st layer print
Looks like too small z-height (nozzle too far away from the bed) to me.
What kind of material do you use? Which sheet? Post a pic of the rectangle at the end of first layer calibration still on the bed, please.
Respondido : 22/02/2023 11:51 am
Is this a new machine?  Prebuilt or kit?  Re-run your XYZ calibration, if that's OK then run the first layer 'Z' calibration and show us the result *on the print sheet.*
Respondido : 22/02/2023 7:25 pm
