displacement y axis
Frigo007
(@frigo007)
displacement y axis
I have a problem that with large prints, there are a few small displacements in the Y axis. The X axis is all right.
Thank you very much for your advice
Postato : 03/08/2019 7:10 am
RE: displacement y axis
There are artifacts that happen when the layer print time falls below certain thresholds.  This may be what's happening.  The effect may be a minor bulge, or a small wall shift, or just a texture change due to perimeter print speeds, or even a directional change.
Turning down one of the slice cooling options can help, as can reducing print perimeter speeds, or even adding a perimeter.  There are many reasons for the artifacts, and many solutions.  No single catch-all to be offered.
Here's a fairly deep dive into the subject: https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/buldge-when-print-reaches-solid-layers/
But, I came away with slowing perimeters to improve "sheen" consistency on glittery PLA, and reducing unexpected speed changes do to cooling settings.  I even went lower than 6 to get the best results on test cases, and set perimeters to 20 mm/s when I was using Prusament Mystic Brown.
Questo post è stato modificato 7 years fa da --
Postato : 03/08/2019 11:52 am
Frigo007
(@frigo007)
Thanks for the tip. I will try. It's just weird that when I used GCODE directly from Prusa and they have it according to the photos have OK.
https://www.prusaprinters.org/prints/4605-wall-mounted-drybox-with-sensor/files
So if it's not something hardware
Postato : 03/08/2019 12:44 pm
Close inspection of the post show the same artifacts on his parts.
Questo post è stato modificato 7 years fa 2 tempo da --
Postato : 03/08/2019 12:49 pm
