Continuing first layer issues
BMet
 BMet
(@bmet)
To high?  To low? To fast?
Napsal : 16/08/2021 12:26 pm
BogdanH
(@bogdanh)
Is too high. You shouldn't be able to see print sheet between the lines on fist layer -that is, first layer must be solid.
[Mini+] [MK3S+BEAR]
Napsal : 16/08/2021 2:06 pm
I disagree.  If anything you are a fraction too low, 'though your picture isn't sharp enough to be certain.
Your adhesion problems are caused by a dirty print-bed.  Look up threads here about cleaning your steel  sheet.
Cheeerio,
Napsal : 16/08/2021 3:36 pm
BMet
 BMet
(@bmet)
High
I got closer and it got better (acceptable).  Printing a large piece now and I'll try closer still on the next piece.  Thanks!
Napsal : 16/08/2021 10:49 pm
BogdanH
(@bogdanh)
Here's just another of many first layer photos (PLA printed on smooth PEI sheet):
[Mini+] [MK3S+BEAR]
Napsal : 17/08/2021 9:37 am
Update
Where were you able to gain success?  With all the disagreement, I can't wait to hear the solution.
Posted by: @brian-mettlen
Napsal : 17/08/2021 10:35 am
