Consistently Failed Prints
Glenn
(@glenn-2)
I've had my printer for about 5 months now, I3 MKS. Recently I cannot get a completed print of designs I've previously had no issue with. The print will start and lay down quite a few layers successfully. Then the extruder  stops and moves to the front corner of the bed. The LCD display then asks to remove the filament and replace it. I go through that motion only to have it happen again and again and again... Ultimately I cancel a print and try again. I clean the nozzle, both internally (cleaning filament) and externally before every print.   I don't store my filament in bags but do run a several hour bake at 55°C to dry them out.  I've tried multiple designs across multiple filaments. I'm stumped. Any suggestion would be helpful. Thank you.
Opublikowany : 15/08/2020 11:55 am
Loak
 Loak
(@loak)
RE: Consistently Failed Prints
Maybe this could help you ?
MK3s Stock, PS2.3, Fusion360, Debian, Windows 10.
Opublikowany : 15/08/2020 12:33 pm
Glenn
(@glenn-2)
@loak
Thanks. I’ll give that a try. Appreciate the input.
Opublikowany : 15/08/2020 12:44 pm
