Completed the kit but runed into this 🙁
stanciu.d
(@stanciu-d)
Hi guys,
I was so excited that I finished mounting the printer and just when I was ready to dive into it's first run this happened.
I am a complete beginner into 3d Printing I mean without instructions and book I can't really do anything. I added two videos showing the problem I hope I alerady did not broke the extruder 🙁
https://www.dropbox.com/s/kr6fecvxenesxe0/20190324_114232.mp4?dl=0
https://www.dropbox.com/s/ed8c9wagowmlkch/20190324_114808.mp4?dl=0
Can someone help me please? What should I do 😥 ?
Publié : 24/03/2019 10:56 am
GeorgeE
(@georgee)
Re: Completed the kit but runed into this 🙁
Lower the Pinda probe, when nozzle touches the bed should be aboud 1mm between the bed and end of the pinda probe. The manual says to use a cable tie to set the distance, make sure you lay it flat and pick somewhere in the middle of the cable tie. If you already did this check the pinda probe is working, light on means not activated, hold a piece of metal up the end of the probe and the light should go out.
Publié : 24/03/2019 11:04 am
World Terrain Factory
(@world-terrain-factory)
Your PINDA probe is way too high for sure. It isn't even visible in the first video. Here is the image from the assembly instructions for reference.
Publié : 24/03/2019 11:18 am
