Clicking sound from bondtech gears
Page 1 / 2
Sawbin85
(@sawbin85)
Hey all,
I just completed the assembly of my mk3. Was a ball to build as I'm sure some of you might be aware. I'm running my first print at the moment after going through all of the calibration with no problems. I'm noticing that when it retracts the filament that the bondtech gears click. Not sure if something is loose or what. I think the tension on the idler is fine. Anyone else had this happen or any suggestions as to what might be causing the clicking in that area??
Definitely not filament issue... print came out perfect. No grinding or anything like that.
Thanks in advance
Posted : 04/05/2018 12:59 pm
Mr.Robot
(@mr-robot)
Re: Clicking sound from bondtech gears
You're not alone.
After assembling the printer worked well, after a short time (runtime ~4 hours) I noticed a clicking noise from the bondtech gears and heavy underextrusion as well. I spend a lot of time to figure out what's possibly wrong, I cleaned the nozzle as well as the hotend, bought a special cleaning filament, disassembeld everything and put everything back together again. I tried PLA (Prusa), PLA (forumfutura), ABS (Verbatim), PETG (formfutura), Greentec (extrudr) filament and spend a lot of time in temperature tweaking, used Prusa Control and slicer (prusa edition) - nothing will work properly.
After all I am not able to use the printer 👿
I am in contact with customer service since 02.apr.18, but they can't offer me a solution.
Posted : 05/05/2018 12:13 am
blueicee
(@blueicee)
try to losen your extruder tensioner (the two screws on the left side of the extruder). the bottom of the screw should be flush with plastic, not the head. i had this issue and that resolved it for me.
Posted : 05/05/2018 3:00 am
Sawbin85
(@sawbin85)
I have put one of the clear washers from the spares bag on the shaft of the idler gear to remove the play. The clicking doesnt seem to be as bad now. I'll adjust the screws so the bottom of the head is flush with the plastic and see what that does as well.
Posted : 05/05/2018 4:59 am
Mr.Robot
(@mr-robot)
one of the tips from the customer service was to play around with the tension of tensioner, so I did with no improvement at all 🙁
I tried the tip with the spare washer, the clicking sound will be less noisy but it still appears.
First attemp was with FormFutura PETG
Second attemp was with the Prusa PLA to rule out errors with the material and / or Gcode
In booth cases, clicking sound from the bondtech gears and under extrusion.
The temperature is stable without break-ins.
Will be thankfull for any other advice, at the moment the printer is useless 🙁
Posted : 06/05/2018 10:48 am
Mr.Robot
(@mr-robot)
Hi Folks,
it took a while but the customer support send out a new hotend. I received the hotend yesterday and assembled it immediatly. Until now the printer works perfect! Total printing time with the new hotend is about 17h with no issues at all!
Posted : 12/05/2018 1:06 pm
Mr.Robot
(@mr-robot)
And the issues comes into play last evening. Starting with slight under-extrusion and a few hours later the clicking sound occurs. Now I'm unable to print again, only clicking and underextrusion no matter what I do, nothing will work.
Disassembled the hot end, checking PTFE tube, cleaned the nozzle, no change at all.
I am very dissatisfied with the situation 👿
Can somebody give me any advise? Am I the only one with this problem?
Posted : 10/07/2018 5:25 pm
stoofer
(@stoofer)
One not uncommon problem is that the shaft of the idler gear can slide out from one of the mounting holes, causing the idler to become loose. Worth checking (and adding a dab of glue to try and stop it happening again if it is the problem)
Edit:
other times I've had this:
[*]Filament sensor died and heated up the filament so much it melted in the extruder rather than the hot end(!)
[*]Filament was bad and varied in diameter up to 2.1mm(!!)
Posted : 11/07/2018 12:17 am
Brien
(@brien)
I'm pretty much in the same boat.
Posted : 11/07/2018 6:04 am
Brien
(@brien)
Yeah, mine just died too, support is supposed to be sending me a new one. Won't get past self test without that working.
Posted : 11/07/2018 6:05 am
Mr.Robot
(@mr-robot)
Getting no answer from the support since july, 12 🙁
Maybe it's a coincidence, but the error did not reappear until I activated the filamentsensor. I was prepareing for a over night print job, turned the filament sensor on and since then I'm in bad trouble with the bondtech gears, nothing will work.
I actually lost all confidence in the device.
Posted : 17/07/2018 8:01 pm
[...] Maybe it's a coincidence, but the error did not reappear until I activated the filamentsensor. I was prepareing for a over night print job, turned the filament sensor on and since then I'm in bad trouble with the bondtech gears, nothing will work.
Needless to say, enabling the filament sensor does not normally cause problems with the bondtech mechanism. When you say "nothing will work", what exactly do you mean?
  • Are you just getting clicking but no filament feed? That sounds like the extruder tensioner screws might be too loose. Check other threads regarding the idler being stuck or misaligned.
  • Is filament being pulled in but not extruding, or getting wrapped around inside the extruder? That could be a jam above the hotend.
  • Is filament being extruded, but not normally? That could be a partial jam further down in the hotend or nozzle.
  • Is everything feeding normally, but you're just getting clicking noises? That may simply be overly-aggressive feeding in your slicer, and can vary depending on your filament. Try slowing the print WAY down (say 50%) using the dial on the front and see if the clicking stops. If so, tweak your flows so as not to out-run the extruder's capability. This may tie in with changes in filament, nozzle sizes or slicer settings.
  • Are you printing in unusual environmental circumstances? Are you using an enclosure, or working in a hot or cold environment?
  • Edit: Reading through the thread, it looks like you've eliminated a couple of these, but this is the "usual list" of things that come to mind.
    The biggest complaint I've had with the filament sensor has been erroneous empty triggers using high-gloss or transparent materials.
    Posted : 17/07/2018 8:31 pm
    Steven S
    (@steven-s-2)
    This has been happening to me as well. I can print the first 8-10 layers and then I start to hear a clicking. Then after another layer or 2 it gets worse and I notice the filament is not advancing and can see the drive gears are not moving or appear to jump both directions.
    After observing for a while I checked the set screw holding the drive gear on to the stepper shaft. it was tight and the alignment of the filament through the 2 drive gears was correct. I played with the tension on the 2 screws with springs both loosening and tightening and there was no change. I even switched filament and both spools were the new Prusa filament they manufacture.
    Additionally, this situation usually happens after I've been using the printer for several hours or more. Very seldom, if ever has this happened when I first start a long print job.
    Finally, I watched the stepper motor shaft where it faces the front of the machine and put a mark on it with a Sharpie so it was easy to see if it was turning and which direction. As I watched i saw the shaft either not moving or moving very quickly and then stopping or it would turn a little and then jump back the opposite direction and a clicking noise when this happened,
    I have a feeling the issue is actually with the stepper motor and possibly after it gets too hot. There is a possibility it's in the firmware and possibly being triggered by bad Gcode but my bet is on a stepper issue. This would also explain why the issue is resolved if the hot-end assembly is replaced. If it is the stepper motor perhaps another fan of the motor or a different motor with a higher temperature tolerance.
    Mr. Prusa, what say ye? Or anybody else. Can anybody else confirm the stepper shaft not rotating when this happens? You will probably need to mark the end of the shaft and it can be difficult to tell if it rotates.
    I would like Prusa to send me a replacement stepper for the hot-end to see if the problem disappears. 🙂
    I have a video if anyone is interested.
    Thanks - Steven
    Posted : 20/10/2018 11:50 am
    Two things are likely this far into a print:
  • The printer has been running for a while and everything has warmed up. You may be hitting a critical level with temps and heat creep.
  • You may be into areas of the print with lots of infill. Infill prints at the highest speeds if you're using Prusa's settings. This can cause a variety of problems depending on settings, material and the model you're printing.
  • [...] After observing for a while I checked the set screw holding the drive gear on to the stepper shaft. it was tight and the alignment of the filament through the 2 drive gears was correct. There were many reports of similar problems, particularly as we went into the unusually hot summer months this year. There's no one cause. The extruder tension screws you mentioned have been cited (along with stuck idler gears on the extruder door), as well as excessive retractions, PTFE tube fittings and a number of other issues. Warm ambient temps and the use of enclosures also caused problems. Prusa released the re-designed R3 extruder parts, which has helped in some instances. I personally have been able to mitigate the issue with slicer settings. Rather than try to re-type everything here, I've compiled a list of common issues I encountered and attempted to help with here.
    Finally, I watched the stepper motor shaft where it faces the front of the machine and put a mark on it with a Sharpie so it was easy to see if it was turning and which direction. As I watched i saw the shaft either not moving or moving very quickly and then stopping or it would turn a little and then jump back the opposite direction and a clicking noise when this happened,Rather than marking up the shaft and squinting, you might want to print off one of the many extruder visualizers. They make it very easy to monitor the flow of filament, retractions and any skipping.
    Posted : 20/10/2018 7:39 pm
    Steven S
    (@steven-s-2)
    Thanks for the prompt reply and good advice. I've continued to test and have found the issue is probably related to a particular part(s). I am having consistent problems printing this part from the Bear Upgrade for the MK3 - build_helper_106mm. After having issues with this part I printed several other parts without issue then tried the "problem" part again and it failed. I also tried turning off the printer until the hot-end was cool to the touch and the temps on the display were ambient and retried the part without success.
    I've loaded the STL into Prusa Slicer and selected Volumetric flow rate in the drop-down box but can't see the "rate" displayed anywhere, only the part now shows different colors. In the area where the problem shows up it is red so I'm guessing this is exceeding what it should be. Is there someplace I can set the max. flow to 11.5 so that this is reflected in the Gcode? The Slicer is set for OPTIMAL MK3, Prusament PLA and Original Prusa i3 MK3 and I've not customized any settings.
    I'm using 1.41.0+win64 so this version may display differently that the version used used in your blog. I also cannot select the checkboxes for Retractions or Speed to tell if there are issues there as well.
    All other items in your great checklist seemed to be OK and nothing else stuck out as a potential problem area.
    Visual Indicators - I wondered what those were used for.... Duh on my part... 😮
    Thank you for your valuable time. If you can help me through using the Slicer and its settings, this will be a great help. I don't know how to identify Flow, Speed or Retraction problems or correct. These seem to be the areas I need to focus on.
    Posted : 20/10/2018 9:10 pm
    [...] I am having consistent problems printing this part from the Bear Upgrade for the MK3 - build_helper_106mm. After having issues with this part I printed several other parts without issue then tried the "problem" part again and it failed.
    Can you provide a link to the STL file(s)? I can pull the part up and take a look.
    I also tried turning off the printer until the hot-end was cool to the touch and the temps on the display were ambient and retried the part without success.It might just be complex enough to cause heat problems quickly. Try dialing speed way back on the front panel -- I'd say 50% -- as it nears the problem areas. If it succeeds (slowly) then you know it's a fix in your slicer settings that you need.
    I've loaded the STL into Prusa Slicer and selected Volumetric flow rate in the drop-down box but can't see the "rate" displayed anywhere, only the part now shows different colors. In the area where the problem shows up it is red so I'm guessing this is exceeding what it should be.Have you saved the gcode file? If not, you'll only see the basic preview:
    Save the gcode out and more options are enabled. You'll also see print time estimates and related info:
    Is there someplace I can set the max. flow to 11.5 so that this is reflected in the Gcode? The Slicer is set for OPTIMAL MK3, Prusament PLA and Original Prusa i3 MK3 and I've not customized any settings.There are 2 places you can set Max Volumetric Speed (MVS):
  • Under Print Settings->Speed->Autospeed (advanced)->Max volumetric speed for any prints using these settings. Prusa defaults this to 0. I set it to 11.5mm^3/s to reflect the limitations of the E3D V6 hotend for all materials I use, effectively a printer-wide maximum.
  • Under Filament Settings->Advanced->Print speed override->Max volumetric speed. Prusa sets this to 15 for PLA, 8 for PETG and a variety of speeds for other materials. If I encounter extruder clicks with a new material, I start lowering this value. 15 is (IMO) way too high given the throughput limits of the E3D V6 hotend.
  • The beauty of this approach is that you don't need to fiddle with your extrusion width, layer height or linear speed settings. It will print up to the speeds, acceleration, jerk and other settings you've specified, throttling only when necessary to maintain safe extrusion rates. I've got a lot more notes on this topic here.
    I'm using 1.41.0+win64 so this version may display differently that the version used used in your blog. I also cannot select the checkboxes for Retractions or Speed to tell if there are issues there as well.I suspect that's due to not having saved the gcode.
    It takes a bit of trial and error.
  • If your print consistently fails printing infill, take a look at speeds. Prusa defaults to very aggressive 200mm/s infill speeds, which are higher than their 170mm/s move speeds. MVS is a function of Layer Height X Extrusion Width X Speed, so high speeds with higher or wider extrusions can definitely cause problems. "11.5mm^3/s. It's the law."
  • If your print consistently fails at the same location, look for lots of small areas like fingers. Turn on retraction preview. If you see clusters of retractions in failure areas, they may be happening so quickly (you'll hear the staccato of retractions) that it generates enough heat to creep into the cold zone and cause problems.
  • If you're getting extruder clicks and bucking, look at Volumetric flow rate. Look for areas exceeding 11.5mm^3/s.
  • My notes and disclaimers on 3D printing
    Posted : 20/10/2018 9:32 pm
    Steven S
    (@steven-s-2)
    Thank you... Saving the Gcode was the trick.
    Changing the Flow to 11.5 changed the all the red areas to dark green/teal, after saving the Gcode.
    I'll try with this version of the part and post the results. The file at issue is from the Bear MK3 Full Upgrade at https://github.com/gregsaun/prusa_i3_bear_upgrade
    Sorry but there is no direct link to the parts but the part is builder_helper_106mm.
    Thanks again.
    Posted : 20/10/2018 9:46 pm
    [...] Sorry but there is no direct link to the parts but the part is builder_helper_106mm.
    Hmm. That's a pretty simple part.
  • There are a few retractions near the 100mm text but nothing crazy.
  • It is hitting 160mm/s in the infill areas. That's also where it's pegging my extrusion limit of 11.5mm^3/s. If I change my limit to 15mm^3/s, it's hitting that rate on infills. Is that where if fails?
  • What settings & material are you using?
    Posted : 20/10/2018 9:56 pm
    Steven S
    (@steven-s-2)
    Yes, agree this is a pretty basic part. Immediately after the last failure I printed a Benchy as a sanity check. It printed perfectly.
    I'm using the stock MK3 settings and using Prusament settings. The part was failing at different layers and these layers were the ones that were red in Slic3r with respect to Flow Volume. I changed the Flow to 11.5 per your suggestion and am currently printing the part. It is currently past the "red" areas where flow was an issue and not a "click" to be heard! Knock on wood but since I'm beyond the troublesome layers think flow must have been the issue.
    Thanks to your help with this and educating me on how to do some basic reviewing of parts with Slic3r, you have taken me to the next level. The part just completed and is perfect!
    Thank you! Your blog is bookmarked.
    Posted : 20/10/2018 10:56 pm
    Rob W
    (@rob-w-3)
    https://drive.google.com/file/d/10Rtop6o8_nNkvcPUgViijg8DbqGxQNA0/view?usp=sharing
    My print is also failing and there is a clicking noise when either i print stuff or try to load new filament. It only loads about 9cm of filament before the clicking starts.
    Any ideas on why it will not load the new filament???
    Posted : 20/11/2018 7:49 pm
    Page 1 / 2
