Can’t insert nylon filament during assembly
ab2print3d
(@ab2print3d)
I have struggled for two hours trying to get the nylon filament specified in Chapter 5 of the assembly manual to hold properly when inserted into the hole on the rear of the extruder assembly. It keeps pulling out, sometimes right away and sometimes after gentle tugging. I have tried a beveled, wedge-shaped end, a flat end, and a pointed end. I have tried inserting the end dry and with lubrication. Nothing works.
I am considering just using zip ties to hold the nylon filament in the bundle of wires. Is that a good approach or should I continue this futile attempt to get the filament to hold properly?
Questa discussione è stata modificata 6 years fa da ab2print3d
Postato : 02/08/2020 12:17 am
JustMe3D
(@justme3d)
RE: Can’t insert nylon filament during assembly
Have you read the user comments to the respective step in the online (sic!) assembly manual? I seem to recall that there is a trick with heating the tip of the filament, slightly thickening it.
Postato : 02/08/2020 12:45 am
