Can I manually move the print bed / e-axis after printing?
ATrain
(@atrain)
First time using a 3D printer (MK3S+ kit) and I just got mine turned on and am working on the first layer calibration.
While I'm testing prints and I stop it early, the e-axis (print head?) stays low and over the plate. I've discovered the "hold knob for 2 seconds" to quickly move the Z-axis, but can I just grab print bed (y-axis?) and move it closer to me so I can more easily remove my print?
Or does that screw all the calibrations up that I've previously done?
Best Answer by BogdanH:
Yes, you can move bed forward/backward by hand -just do it slowly. If moving too fast, stepper motor will generate electricity which goes back to mainboard (visible on display flickering) and can potentially damage it.
Veröffentlicht : 13/12/2021 11:56 pm
BogdanH
(@bogdanh)
RE: Can I manually move the print bed / e-axis after printing?
[Mini+] [MK3S+BEAR]
Veröffentlicht : 14/12/2021 11:22 am
Milos V.
(@milos-v)
As adviced, you can move manually. If not possible, choose from printer menu command to switch off the motors. Another choice is from printer Menu - Settings use direct commands to move all axis. Very usefull.
Veröffentlicht : 14/12/2021 9:56 pm
