[Risolto] Calibration Wizard question
SWAG_4_1if3
(@swag_4_1if3)
So I am going through the calibration wizard and I'm at the point where the printer goes through the 24 min calibration.  So I remove the steel sheet and place a piece of paper on the bed and start the calibration.  The instructions say that if the nozzle catches the sheet to turn the printer off immediately.
At some point I see the paper move so I'm assuming that means the nozzle is catching the sheet so I turn the printer off immediately.
What do I do next to fix the issue?
Postato : 26/02/2025 7:43 pm
Artur5
(@artur5)
RE: Calibration Wizard question
What Prusa probably meant was that if the nozzle grabs the paper too hard until it tears it, then turn off the printer. It's perfectly normal for the paper to move a bit during this procedure. The nozzle has to make solid contact with the bed. Keep watching the calibration and gently reposition the sheet of paper if you see it dragging too much sideways. Try to always keep it under the nozzle.
Postato : 27/02/2025 10:11 am
SWAG_4_1if3
(@swag_4_1if3)
Got it.  Thanks for clearing that up.  I'll fire it up and give it another go keeping all that in mind.
Postato : 27/02/2025 1:28 pm
