Calibration Failed
Jeff.Juarez.Design
(@jeff-juarez-design)
Calibration Failed
Greetings,
First-time user/builder, but experienced technical person.
I just finished building my i3 MK3 Kit, and I'm getting a calibration error.
I've run through the initial self-check and all was good. It does the X and Y axis check, then runs up to the top of the Z axis for top out, and there the carriage stops.
It then asks you to remove the steel sheet, followed by reminding you to put down a sheet of paper.
From here, the Carriage stays at the top of the Z axis, and I get a Calibration failed notice.
Everything seems fine. I took my time and assembled everything correctly as far as I can surmise. Hot-end is fully installed, the trapezoidal nuts are not reversed...
Any suggestions? Thanks!!
Napsal : 20/09/2018 5:05 pm
Jeff.Juarez.Design
Re: Calibration Failed
Only thing I notice maybe out of the norm is the extruder-stepper is a bit warm for just sitting there. Much warmer than the other components.
Napsal : 20/09/2018 5:07 pm
thrawn86
(@thrawn86)
its more sensitive during calibration, as opposed to just smashing the carriage all the way up. something may be causing it to bind all the way at the top. I like to leave the nuts loose, top out z by turning the screws by hand and then hand tighten the nuts again.
normal for the stepper.
Napsal : 21/09/2018 7:09 am
Jeff.Juarez.Design
Problem Solved!
Solution? I'm an idiot and made a mistake in assembly- somehow plugging the extruder into the PINDA probe port on the board, and the PINDA probe plug got lost in the rats-nest of wires and was never plugged in to begin with.
She's now up and running, and printing like a dream. This machine is FANTASTIC. I heart Prusa.
Napsal : 21/09/2018 8:35 am
