Calibration fail
Maneria
(@maneria)
Calibration fail
Hello Prusa-community,
I have a problem with my mk3. I need to calibrate them but he makes little jumps between each calibration point. So I replaced my pinda with a new and set it in the right hight. But I not works, I uploaded 2 video to YouTube. So u can see my problem.
https://youtube.com/shorts/94siFv086Wk
I hope anyone can help me.
Best wishes
Stefan
Veröffentlicht : 23/03/2021 6:44 am
Dan Rogers
(@dan-rogers)
RE: Calibration fail
is normal.  It is seeking the magnets under the printed circles.  Aren't you supposed to have a sheet of paper between the head and the metal?  that could make a diff since it is seeking the point where it barely drags the paper.
Veröffentlicht : 23/03/2021 8:59 pm
Clarmrrsn
(@clarmrrsn)
Yip, thats the normal adjustment, remember how long it took, was a long 12 minutes.
And yes Dan, you are correct  needs a sheet of paper under the head on all 4 points, says if it catches the paper at any point to switch off immediately (And it will restart the adjustment I assume)
Tank you very much!
Veröffentlicht : 23/03/2021 10:09 pm
3Delight
(@3delight)
Moderator Moderator
Can also confirm that this is correct behaviour, just done a recalibration on mine (MK3S+) and that's exactly how it works.  Takes ages and is very noisy!  As Dan says it is important to have a sheet of paper (just ordinary A4 photocopier paper will do) between the nozzle and the bed at each point.  It will protect the bed if there are any problems!
Veröffentlicht : 23/03/2021 10:20 pm
