Bricked my printer?
anthony.m26
(@anthony-m26)
Bricked my printer?
I was having issues with Y-alignment, so I re-ran the self-check wizard. The wizard reported that there an issue on the Y axis, and I tried to inspect. In doing so, I pushed the print bed along the Y-axis with the power on, which in retrospect might have been a bad idea. My printer powered off and won't come back on no matter what I do. I'm hoping I haven't destroyed the printer.
Thanks!
Postato : 23/12/2018 12:57 am
LA 3D Printer Repair
(@la-3d-printer-repair)
Utenti
Re: Bricked my printer?
Moving the axis with the printer on should not cause a problem.
Disconnect power, inspect your Einsy power lugs for loose connection as an initial sanity check, then plug in, turn on, let us know what happens.
Postato : 23/12/2018 1:21 am
anthony.m26
(@anthony-m26)
Thanks. The connections seem fine, and after several attempts plugging and unplugging it seems to be powering up again. Not sure what happened there.
Postato : 23/12/2018 1:29 am
Utenti
Good to hear, run a print and confirm its happy printing again.
Postato : 23/12/2018 1:34 am
anthony.m26
(@anthony-m26)
Well, not quite. I'm back to the Y axis. I'm fearing that the bearings are too tight. Strange, as it passed the self-check when I first completed it, but it's failing the self-check now... but that's another topic. Thanks for the tip on this one!
Postato : 23/12/2018 3:45 am
Utenti
You’re welcome!
But if you’re just getting a Y Axis failed the likely culprits are too loose Y belt and pulley not on flat which allows the axis to slip enough that the machine says “that ain’t right”.
I’ve seen a bad y bearing but if you can move it smoothly by hand with the unit off, your bearings are probably ok.
Let’s get you printing again!
Postato : 23/12/2018 9:44 pm
anthony.m26
(@anthony-m26)
Thanks! Just seeing this reply. I posted another question about the Y axis issue with a video. Could you clarify what you mean by "pulley not flat"? The belt is as tight as I can get it by hand. I'll see if I can tighten the screws on the pulley.
Postato : 24/12/2018 4:37 am
Utenti
There is a flat side on the motor shaft, make sure the grub screw holding the pulley to the shaft is against the flat side of the shaft.
Postato : 24/12/2018 4:50 am
anthony.m26
(@anthony-m26)
Sure enough! The flat side wasn't aligned with the grub screw. It's back to passing its self checks and calibration. That's progress! I'm optimistic that that loose pulley was the y-alignment issue too. Thanks again!
Postato : 24/12/2018 5:30 am
