Blobs issue
Rocky79
(@rocky79)
Blobs issue
Hello,
How do I get rid of the blobs shown in the shot below?
I am printing with Prusament silver PLA at 220C, 3 perimeters, gyroid 50% infill and the rest are left at the default prusa slicer setup.
Thank you
3D print Blobs
This topic was modified 5 years temu by Rocky79
Opublikowany : 24/07/2021 10:51 pm
Likely overhangs
If those hex shaped openings are hollow tubes, you're likely seeing defects due to overhangs. A lower layer height might help.
Save your current  3MF project file, zip it up, and attach it to a reply here so we can see your part & settings and give better recommendations.
Opublikowany : 24/07/2021 11:12 pm
Rocky79
(@rocky79)
Project file
Thank you for your reply. Please see attachedHolder V2 Forum.3mf
Opublikowany : 25/07/2021 2:09 am
Try calibrating extrusion multiplier
Ah, OK. Not overhangs at all. You've got some over extrusion on the inside of the hollow hex tube.
  • I'd start with calibrating your extrusion multiplier to be sure it's not just putting out a bit too much filament. If your printer is not a Prusa, have you done an e-step calibration?How do the outside walls look?
  • You've got 50% fill density set which can aggravate over extrusion with a small print. How does it look with 15%?
  • How does it look with 2 perimeters?
  • Your printer preset is named Creality but looks to have Prusa gcode. Is it working OK otherwise?
  • I notice you've got Print Settings->Multiple Extruders->Ooze prevention turned on from the default off. This shouldn't cause any problems, but worth flipping just to be sure.
Opublikowany : 25/07/2021 4:39 am
Rocky79
(@rocky79)
RE: Blobs only on the inside
Posted by: @bobstro
Thank you. Do you have a recommended way to calibrate the extrusion multiplier? ( I saw Prusa has write up on this topic)
I am using the Prusa Mk3.
I tried 15% before, it’s less blobs but it’s still there however the part was not strong enough .
The rest of the part look good on the outside. On the full model, I have multiple Hex slots, the blob problem only shows on the first one.
This post was modified 5 years temu by Rocky79
Opublikowany : 25/07/2021 5:02 am
Ringarn67
(@ringarn67)
A bug
Posted by: @bobstro
When I open up his 3mf-file PS choose the printer "Original Prusa MINI & MINI+"
Probably this is the same problem as in this thread. You, and I, don't have Prusa Mk3 installed so PS choose the first name on the list, which in my case is Prusa Mini and your case I assume is a Creality printer
If this is the case it's a well known bug that should be fixed in 2.4
Prusa i3 MK3S+ FW 3.11.0 (kit dec -20), PrusaSlicer 2.6.1+win64, Fusion 360, Windows 10
Opublikowany : 25/07/2021 7:17 am
Use Prusa calibration article
Sorry, I meant to include the link to the Prusa article. Looks like you found it.
Interesting about the preset bug. I do have a Mk3s preset installed. Sounds like a few things can trigger the bug. Anybody know if a GitHub issue has been opened?
Opublikowany : 25/07/2021 3:40 pm
Rocky79
(@rocky79)
Prusa Mk3
Thanks for the reply.
I have the Prusa Mk3. I am not sure why it says creality. Was there a work around the bug?
Opublikowany : 25/07/2021 5:48 pm
Ringarn67
(@ringarn67)
Tested and verified
Posted by: @bobstro
Yes, but he is having the Mk3, without "s". I installed "Mk3" just a moment ago to test this, again, and it looks like this:
If I uninstall "Mk3" it looks like this:
And it is because "Mini" is the first one in my printer list.
I bet the first printer in your list is a Creality
If you read the thread I linked to, and look at what and how I tested it you see what is happening.
Yes, I open an issue and it was closed within an hour or two. As said, it has been fixed in 2.4 alpha.
In 2.4 PS temporary install the files that is needed, as seen in This Post
Opublikowany : 25/07/2021 6:39 pm
1 ludzie polubili
Ignore the bug!
Posted by: @rocky79
It's not important, just confusing. The settings were for a Prusa which is why I was confused. Don't let that distract you, sorry.
Opublikowany : 25/07/2021 7:45 pm
Ringarn67
(@ringarn67)
@rocky79
Posted by: @rocky79
The settings "inside" is correct, it is just the name that is different.
In this particular case it means that all the PrintER settings are for Mk3, even though it, for ME, says "Original Prusa MINI & MINI+", and for @bobstro says "Creality ...".
I don´t know of any workaround beside check if settings seems correct.
If you look at the attached picture, the screen capture is from your file, I have NOT Mk3 installed, the settings are clearly for "MK3" and the name is "Original Prusa MINI & MINI+"?!
This has happened to me several times when I download files from this forum.
Let's hope for quick release of Prusaslicer 2.4, then all this will be gone 😊 , hopefully 😏
Opublikowany : 25/07/2021 8:06 pm
Rocky79
(@rocky79)
RE: Inside Walls still not smooth
I am still having issues with the rough texture on the inside walls of the hex shape. The outside finish is good, it’s only the inside. That surface needs to be smooth.
Any idea how to achieve that?
BTW, I fixed the blobs issues by disabling the Z retract.
Opublikowany : 04/08/2021 6:31 pm
