Bending from plate
I have a, at least for me, weird issue.
Tonight I printed 5 parts in an 11 h print and I got some banding, but only on two of the 5 parts.
I think I have a good first layer but I'm new so call me wrong.
Do you have any other explanation except dirt or wrong firs layer calibration?
Thanks in advance 🙂
Hagen
RE: Bending from plate
The parts are lifting off the bed so you have an underlying bed adhesion problem. You may also have a warping issue due to temperature gradients but I would expect that to be more visible on the larger parts.
Give your print bed a really thorough clean. This might be enough. If not please show us a picture of the bottom of your print, or of the first layer.
This is warping and it is either adhesion or cooling of a filament that does no like it.
