Benchy first print fail twice
Gemini1364
(@gemini1364)
Hi,  I recently assembled my Mk3S and attempted to print the supplied Benchy file.  It made it to the roof and while I was watching it it placed a glob of material that seemed to be accumulating on the nozzle on one of the door arches.  When the nozzle came around to this position again, the glob had hardened and the nozzle touched it and dislodged the model from the bed and thus failed.  I made another attempt and it failed in the same spot, but this time, no glob was formed but as you can see in the pictures, the overhang for the arches seem to be heading upwards which is what the nozzle hit this time around.  It almost seems like a cooling issue like I see in metal welding where the cooling makes the material contract and pull.  Any ideas on how to remedy this?  I'm new to 3D printing and have all of the settings at their defaults.
Thanks for any assistance!
Opublikowany : 10/09/2020 3:54 pm
Colibri Synthetics
(@colibri-synthetics)
RE: Benchy first print fail twice
Hello,
your first layer is not bonding to the heatbed properly. You need to check the first layer calibration and get that one done before moving on to your next test.
Opublikowany : 10/09/2020 4:09 pm
bobstro polubić
Gemini1364
(@gemini1364)
Thanks for the quick reply!  I did make an adjustment after the second fail and will try again.  I wasn't sure if this was a first layer issue as you can see the overhang start to curl up while the rest is at the current layer level.  I thought that this would hit and dislodge even if bed adhesion was optimal. I did the tree frog after the adjustment and it turned out great but it doesn't have the height that the tug boat has.
Still lots to learn!
Opublikowany : 10/09/2020 4:22 pm
GKMAKEIT
(@gkmakeit)
If you have a hard time with the first layer cal that comes on the machine try this...
Opublikowany : 10/09/2020 4:32 pm
Gemini1364
(@gemini1364)
Thanks for the video link.  Subscribed!  I watched another video and he mentioned to just keep lowering until when you drag your finger across the zig-zag it doesn't move.  The video method seems more in line with others I have talked to.  Essentially making the small square bond to itself instead of like an accordion.  Now I know what to keep my eyes on.
Thanks!
Opublikowany : 10/09/2020 5:35 pm
jsw
 jsw
(@jsw)
I swear by those 3x3 test prints that print relatively quickly and show you the center and the corners.  They are a good sanity check to run every so often to be sure you have it dialed it correctly.  See photo below.
I also suggest changing to the 7x7 bed auto-level via the front panel.  I recommend 7x7 with 5 samples.
Opublikowany : 10/09/2020 6:21 pm
Gemini1364
(@gemini1364)
I'm definitely going to look into this, thanks!  I saw in the video that the machine was doing quite a bit more level check points than mine has been doing.  I haven't explored the interface enough, I guess.
Opublikowany : 10/09/2020 6:26 pm
Gemini1364
(@gemini1364)
Posted by: @jsw
Is this included on the SD card or in the interface somewhere?
Opublikowany : 10/09/2020 6:29 pm
7x7 mesh bed levelling is available via the LCD menu, I think it's under settings.
Opublikowany : 11/09/2020 12:53 am
Technical Ted
(@technical-ted)
@thode-t Did you have find a solution to this problem? I'm having the same issue and I don't think it's an issue with the first layer bonding to the print sheet.
Thanks,
Ted
Opublikowany : 12/03/2021 11:38 pm
Colibri Synthetics
Posted by: @technical-ted
Thanks,
Ted
Can you describe what your printer does? Maybe add a picture or two.
Opublikowany : 13/03/2021 12:14 am
Technical Ted
(@technical-ted)
@velvia
Please see my post here.  https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/problem-printing-benchy-raised-section-hits-nozzle/
Thank you,
Ted
Opublikowany : 13/03/2021 12:16 am
