Belt Clearance Question. On Step 36 of Assembly. Very Stuck.
Belinda
(@belinda)
How much clearance should there be between the smooth side of the belt and the YZ Frame.  My first thought was that I had installed the Y-Belt Idler upside down, but mine seems to match photo in step 20.  It seems to me that if I continue to Step 37, then the belt will rub against the YZ frame.  I'm pausing until I hear back from someone.
Publié : 01/07/2020 6:06 pm
RH_Dreambox
(@rh_dreambox)
RE: Belt Clearance Question. On Step 36 of Assembly. Very Stuck.
Some images showing your problem would be great to see.
Publié : 02/07/2020 8:29 am
