Belt Clearance Question. On Step 36 of Assembly. Very Stuck.
How much clearance should there be between the smooth side of the belt and the YZ Frame. My first thought was that I had installed the Y-Belt Idler upside down, but mine seems to match photo in step 20. It seems to me that if I continue to Step 37, then the belt will rub against the YZ frame. I'm pausing until I hear back from someone.
Napsal : 01/07/2020 6:06 pm
RE: Belt Clearance Question. On Step 36 of Assembly. Very Stuck.
Some images showing your problem would be great to see.
Napsal : 02/07/2020 8:29 am
