BED TEMP jumps
Lmmohr
(@lmmohr)
BED TEMP jumps
  1. BED TEMP JUMPS FROM 60 TO 110, all new MK3 pre-built. I searched code and there's no code M140 making the change. Anyone else have this problem?
Napsal : 28/11/2020 9:58 pm
RE: BED TEMP jumps
Posted by: @lmmohr
Could you upload the gcode. Just zip it and put in your "add media".
Napsal : 28/11/2020 11:01 pm
Lmmohr
(@lmmohr)
RE: BED TEMP jumps
@karl-herbert
Napsal : 29/11/2020 3:36 pm
RE: BED TEMP jumps
@lmmohr
your post contains no attachment!
zip the gcode, select "Add Media" and upload the zipped file.
Napsal : 29/11/2020 4:45 pm
RH_Dreambox
(@rh_dreambox)
RE: BED TEMP jumps
Is the temperature sensor under the bed correctly mounted?
Napsal : 01/12/2020 10:06 am
Lmmohr
(@lmmohr)
RE: BED TEMP jumps
As far as I know. It was pre built
Napsal : 01/12/2020 6:51 pm
RE: BED TEMP jumps
@lmmohr
The more information you provide the faster we can help, otherwise we can only speculate.
Do you have the same problem with several MK3 printers? A gcode example would help for analysis...
Napsal : 01/12/2020 7:02 pm
Lmmohr
(@lmmohr)
RE: BED TEMP jumps
PrusaTreeoflifeXX   (zip)
Napsal : 01/12/2020 8:16 pm
