Bed leveling question with these leveling values
Hi all, I have a kit MK3S that I recently connected to OctoPrint to check out the bed leveling, and have attached the values.
I've been reading about how to get the bed leveled besides using the build-in 7x7 mesh function. I would like to avoid doing the nyloc screw technique. I saw one use note retightening screws in a specific order, but I could not find the thread or an article related to this. Would you be able to direct me? Another user mentioned to heat up the bed, loosen and retighten, which I may attempt.
But ultimately, are these values terrible, or generally insignificant? Thank you.
Best Answer by Diem:
That all looks OK, your mesh-bed levelling seems to have accommodated nicely.
- But there are smears on your build-plate. You need to keep it clean or you will have problems.
Are you having adhesion problems?
If so clean the print-sheet and show us a first layer Z calibration print.
RE: Bed leveling question with these leveling values
Hi Diem, adhesion is fine. I am just wondering about the left side being lower, and if I should do something mechanical to correct it. I uploaded some photos of a test grid here: https://imgur.com/a/Zf4WWtF
