Bed Level Correction Test Print
kpmoody
(@kpmoody)
Looking for some second opinions on this. First, does the z calibration look correct?
Second, I see a weird gap in the perimeter mainly in the middle 3 squares at the top of the box. It was even worse on the first few tries I did of this when I used the gcode instead of slicing it myself again with the latest prusa slicer version.
Veröffentlicht : 21/05/2023 4:26 pm
kpmoody
(@kpmoody)
RE: Bed Level Correction Test Print
Just trying to get this up and running again after it has been sitting unused for over a year. I just cleaned and lubed all rods and re-ran the setup wizard last night and this is the first print I'm trying.
Veröffentlicht : 21/05/2023 4:29 pm
Hello
(@hello)
Try doing first layer calabration on the printer under calabration
Veröffentlicht : 21/05/2023 6:58 pm
kpmoody
(@kpmoody)
I've done that, I ran the setup wizard.
Veröffentlicht : 21/05/2023 7:58 pm
kpmoody
(@kpmoody)
Does it look too high or low?
Veröffentlicht : 21/05/2023 9:44 pm
kpmoody
(@kpmoody)
Leveled again and it seems better overall, I was too low I think, but I still have this weird shift on only the middle squares. So confusing
Veröffentlicht : 21/05/2023 10:17 pm
kpmoody
(@kpmoody)
Latest full print. As you can see, weird gap in top perimeter. Any advice welcome, did a cold pull yesterday but could do again.
Using fillamentum black extrafill PLA
I have some prusament white I could try and also transparent blue fillamentum pla
Veröffentlicht : 21/05/2023 10:44 pm
Hello
(@hello)
Your to high by the looks of it print a 20 by 20 mm cube each corner and in the middle that will really help
Veröffentlicht : 22/05/2023 8:41 am
kpmoody
(@kpmoody)
After trying to print some cubes I saw that I had a bad Y axis layer shift for a chunk of like 10 layers. Turns out the grub screws were either not tight or it was not on the flat part properly. After fixing that it seems to be fixed. Will wait to say it's resolved until I do a cube though
Veröffentlicht : 23/05/2023 2:28 am
Hello
(@hello)
Okay keep me updated
Veröffentlicht : 23/05/2023 9:55 am
