Artifacts on Benchy
Endymion
(@endymion-2)
Artifacts on Benchy
I just assembled a Mark 3 and have done some prints. Results generally look good after I got the Z level adjusted; however, I am curious what is causing the artifacts on Benchy on the back of the boat. I'm attaching several views of the print. Any help understanding the artifact causes would be appreciated and any other issues you see in the print.
Thanks in advance,
John
Postato : 06/02/2019 10:29 am
Mojo
 Mojo
(@mojo)
Re: Artifacts on Benchy
The benchy generaly looks good to me.
I would say the ghosting in the back is a result from vibrations from acceleration.
To reduce this it's generally good to tighten the belts and make sure the printer stands on a solid base.
Postato : 06/02/2019 12:24 pm
Endymion
(@endymion-2)
The base on which I have the printer does wiggle some. I'll try a studier base. I'll check the belt tightness again.
Thanks for the help!
John
Postato : 06/02/2019 5:57 pm
When in doubt, dual back speeds using the front knob and compare. That'll help narrow down the problem and differentiate between hardware and slicer issues.
Postato : 06/02/2019 7:01 pm
Endymion
(@endymion-2)
Thanks!
Postato : 07/02/2019 6:09 am
