1st layer problems
Martin Brimson
(@martin-brimson)
1st layer problems
Postato : 02/03/2023 8:05 pm
Martin Brimson
(@martin-brimson)
RE: 1st layer problems
Sorry unable to add my text to the pictures above.
printed 4 copies of the drawing and they all missed bits or did not join the edge in different places. This makes me think not a drawing issue or they would all be the same.
my z setting is -1.438 build plate cleaned with plenty of alcohol and even tried fairy liquid as suggested all to no avail
any help would be appreciated
Postato : 02/03/2023 8:33 pm
What are the smears on your build plate?
Postato : 02/03/2023 8:35 pm
Martin Brimson
(@martin-brimson)
Hi the lines are scratches the items were so thin I had to use a metal blade to release them from the build plate. Thanks
Postato : 02/03/2023 8:39 pm
The first layer 'Z' calibration in the top picture is too high, not enough squish.
The second picture is not sharp enough to tell but in the bottom picture it is a fraction too low.
Try printing a plastic scraper, does less damage.
Are you getting acceptable adhesion with general printing?
Postato : 03/03/2023 5:28 am
Martin Brimson
(@martin-brimson)
Thanks I will try and adjust and put on another picture. Would  this cause the missing lines?  Also any idea what is causing the gap at the edges?
Postato : 03/03/2023 9:20 am
Martin Brimson
(@martin-brimson)
Hi like the post above mine also found grub screw loose . Just re calibrating printer to hopefully sort out missing line problem one sorted one to go
Postato : 07/03/2023 8:20 pm
