0.6 Nozzle switch seam issues
pixelwave
(@pixelwave)
Setup:
  • Printer: Prusa i3 MK3S+
  • Firmware: 3.13.0
  • Prusa Slicer: 2.6.0
  • Nozzle: E3D V6 0.6mm
The only upgrade from the stock Prusa i3 MK3S+ was the nozzle change from 0.4 to 0.6 (genuine E6D from Prusa shop).
I am also only using Prusament (PLA/PETG) with the default Prusa Slicer print profiles for 0.6 nozzle.
When I print with seams the are always open and not really closed anymore ... would could be the issue?
Publié : 31/07/2023 12:38 pm
Avinash
(@avinash)
RE: 0.6 Nozzle switch seam issues
Around what layer height are you using for your prints? (That could be a factor for the issue)
Publié : 01/08/2023 1:15 am
Avinash
(@avinash)
Check to see if any filament is leaking (in case you didn’t screw the nozzle tight enough)
Publié : 01/08/2023 1:17 am
Avinash
(@avinash)
This doesn’t happen often with pla and petg, but based on the pictures given, it may be that the filament has absorbed some water and you need to dry it out.
https://help.prusa3d.com/article/drying-filament_332086
Publié : 01/08/2023 1:22 am
pixelwave
(@pixelwave)
No leaks - already printed a couple of 1 KG spools. I guess that should have been noticeable by now ...
Publié : 01/08/2023 7:23 am
pixelwave
(@pixelwave)
Happens with PLA as well as PETG. Also tried this with a brand new and sealed Prusament spool.
Also after opening I store my spools in a custom low-humidity enclosure (<10%, https://www.printables.com/model/116955-filament-dry-box-4x-ikea-samla-22l).
Publié : 01/08/2023 7:25 am
