How to keep setting of bed temperature
BAS prints
(@bas-prints)
Hi.
I figured out that my optimal bed temperature is 66-67 degree C.
However, I apply the parameter to that value coming from 60 dgree after starting the print.
But I need to repeat this precedure every print, as the printer looses this parameter.
Could I set up this parameter for all my prints?
THX for hlep.
Opublikowany : 10/04/2019 9:43 pm
RetireeJay
(@retireejay)
Re: How to keep setting of bed temperature
That's a setting in your slicer. If you are just re-using G-code that's been previously generated then yes, you'll have to adjust the setting manually every time. But every time you slice an object you have the opportunity to set the bed temperature that will be used to print that object.
Opublikowany : 10/04/2019 10:13 pm
