Aktualizace firmware
VaPe
 VaPe
(@vape)
Tak jsem aktualizoval podle návodu a nakonec mi to napsalo, že aktualizace se nezdařila. Mrknul jsem na verzi a ukazuje 3.10.1 a jede ...
Stáhnul jsem log, ale nevím?
avrdude-slic3r -v -p atmega2560 -c wiring -P COM3 -b 115200 -D -U flash:w:0:F:\prusa3d_fw_3_10_1_MK3S\prusa3d_fw_MK3S_MK3S+_3_10_1_4697.hex:i
avrdude-slic3r: Version 6.3-20160220-prusa3d, compiled on Dec 21 2021 at 17:14:48
                Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
                Copyright (c) 2007-2014 Joerg Wunsch
                Using Port                    : COM3
                Using Programmer              : wiring
                Overriding Baud Rate          : 115200
                AVR Part                      : ATmega2560
                Chip Erase delay              : 9000 us
                PAGEL                         : PD7
                BS2                           : PA0
                RESET disposition             : dedicated
                RETRY pulse                   : SCK
                serial program mode           : yes
                parallel program mode         : yes
                Timeout                       : 200
                StabDelay                     : 100
                CmdexeDelay                   : 25
                SyncLoops                     : 32
                ByteDelay                     : 0
                PollIndex                     : 3
                PollValue                     : 0x53
                Memory Detail                 :
                                         Block Poll               Page                       Polled
                  Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
                  eeprom        65    10     8    0 no       4096    8      0  9000  9000 0x00 0x00
                  flash         65    10   256    0 yes    262144  256   1024  4500  4500 0x00 0x00
                  lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
                  hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
                  efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
                  lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
                  calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
                  signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
                Programmer Type : Wiring
                Description     : Wiring
                Programmer Model: AVRISP
                Hardware Version: 15
                Firmware Version Master : 2.10
                Vtarget         : 0,0 V
                SCK period      : 0,1 us
avrdude-slic3r: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0,00s
avrdude-slic3r: Device signature = 0x1e9801 (probably m2560)
avrdude-slic3r: safemode: hfuse reads as D0
avrdude-slic3r: safemode: efuse reads as FD
avrdude-slic3r: reading input file "F:\prusa3d_fw_3_10_1_MK3S\prusa3d_fw_MK3S_MK3S+_3_10_1_4697.hex"
avrdude-slic3r: writing flash (251278 bytes):
Writing | ################################################## | 100% 45,06s
avrdude-slic3r: 251278 bytes of flash written
avrdude-slic3r: verifying flash memory against F:\prusa3d_fw_3_10_1_MK3S\prusa3d_fw_MK3S_MK3S+_3_10_1_4697.hex:
avrdude-slic3r: load data flash data from input file F:\prusa3d_fw_3_10_1_MK3S\prusa3d_fw_MK3S_MK3S+_3_10_1_4697.hex:
avrdude-slic3r: input file F:\prusa3d_fw_3_10_1_MK3S\prusa3d_fw_MK3S_MK3S+_3_10_1_4697.hex contains 251278 bytes
avrdude-slic3r: reading on-chip flash data:
Reading | ################################################## | 100% 32,73s
avrdude-slic3r: verifying ...
avrdude-slic3r: 251278 bytes of flash verified
avrdude-slic3r: safemode: Fuses OK (E:FD, H:D0, L:FF)
avrdude-slic3r done.  Thank you.
avrdude-slic3r -v -p atmega2560 -c arduino -P COM3 -b 115200 -D -u -U flash:w:1:F:\prusa3d_fw_3_10_1_MK3S\prusa3d_fw_MK3S_MK3S+_3_10_1_4697.hex:i
                Using Port                    : COM3
                Using Programmer              : arduino
avrdude-slic3r: prusa_init_external_flash(): MK3 printer did not boot up on time or serial communication failed
avrdude-slic3r: arduino_open(): Failed to initialize MK3 external flash programming mode
avrdude-slic3r: Could not open port: COM3
Napsal : 25/12/2021 7:32 pm
Viktor
(@viktor)
RE: Aktualizace firmware
Mám presne ten istý problém. Mal som to takto aj pri minulej aktualizácii, ale neriešil som to, keďže všetko fungovalo ako má. Akurát mi nešlo prepnúť jazyk na tlačiarni do CZ, ale ostalo to v EN - pre mňa to nie je problém.
Napsal : 23/01/2022 9:55 am
Zoltan
(@zoltan)
Member Moderator
Je to known bug, mrknete na vlakna resi se to i nagithub - pouzivate linux?
Napsal : 23/01/2022 12:33 pm
Viktor
(@viktor)
Nie. Windows.
Napsal : 23/01/2022 1:07 pm
Viktor
(@viktor)
Viete mi polat nejake linky?
Napsal : 23/01/2022 5:07 pm
Zoltan
(@zoltan)
Member Moderator
https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/problems-upgrading-to-firmware-3-10-1/#post-567817
Napsal : 23/01/2022 6:53 pm
Viktor
(@viktor)
Pardon, ale toto je odkaz na iný problém. Tam im tlačiareň vôbec ani nenabehne, prípadne majú problém so senzormi. Nám sa jedná o problém na konci log-u:
Napsal : 23/01/2022 7:13 pm
Zoltan
(@zoltan)
Member Moderator
Podle výpisu nahrání a verifikace nahraného FW proběhla správně, problém nastal až při bootu - nastartování tiskárny - třeba se něco rozbilo při bootu. Takže FW by měl být správně nahraný.
Pokud se to děje někomu pokaždé, pak by to mohla být systematická chyba v ovladačích com portů?
Napsal : 11/02/2022 9:32 am
Viktor
(@viktor)
Deje sa to vždy. Bola to moja druhá aktualizácia FW, použil som 2 rôzne notebooky a výsledok je stále ten istý. Ale ako vravím, tlačiareň funguje bez problémov.
Napsal : 11/02/2022 10:16 am
VaPe
 VaPe
(@vape)
Asi tak ... Čekal bych, že to proběhne v pohodě, nicméně tiskárna jede.
This post was modified před 4 years by VaPe
Napsal : 13/02/2022 12:46 pm
