Raspberry pi zero WH installation
impression3D.xyz
(@impression3d-xyz)
I just bought a raspberry pi ZERO WH with pins in order to avoid to do weldings, to install it in my MK3S printer,  but once installed it does not hold in place.. someone has someone already tried it and has an idea how to hold it?
Thanks for your help
Dieses Thema wurde geändert Vor 6 years von impression3D.xyz
MK3S and Mini print farm
Veröffentlicht : 05/06/2020 8:12 pm
impression3D.xyz
(@impression3d-xyz)
RE: Raspberry pi zero WH installation
i followed this guide .. : https://howchoo.com/g/mdmwzgfhmjf/octoprint-prusa-i3-mk3s
Veröffentlicht : 05/06/2020 9:11 pm
Posted by: @impression3d
If you do not want to plug the RPI Zero directly onto the einsy board, you can also establish the connection with a ribbon cable or with jumper wires and use your own housing for the Zero like this: https://www.thingiverse.com/thing:3465254
The housing you could mount on the printer frame.
Veröffentlicht : 05/06/2020 11:10 pm
impression3D.xyz
(@impression3d-xyz)
HI,
thanks for your answer. jumper wires is a good idea, with short ones i can put the pi in place on the good location. i prefer to put it at the good location as expected because the cleaner and more practical it is when i move the printer.
the housing is nice for. other printers like ender3 and so on.
Veröffentlicht : 06/06/2020 6:28 am
impression3D.xyz
(@impression3d-xyz)
i bought that i think i will hep to plug the raspberry pi zero WH correctly 🙂 : https://fr.aliexpress.com/item/32589775433.html?spm=a2g0s.9042311.0.0.2c616c37k8in1o
i prefer to put the rpi inside the MK3S, better integration, no external alimentation...  🙂
Veröffentlicht : 06/06/2020 8:07 pm
Calire
(@calire)
Bonsoir.  Tu résides en France ?   Ici  tu peux parler français   nous on aime bien  😋
Sinon   on se débrouille aussi avec la langue de chèquespire, no problèmo.
Veröffentlicht : 07/06/2020 7:49 pm
impression3D.xyz
(@impression3d-xyz)
Bonjour
je pensais avoir posté dans le forum anglais désolé 🙂
Oui je suis francais, d'Alsace 🙂
Du coup pour info j'ai acheté ca pour connecter le rasp zero WH : https://fr.aliexpress.com/item/32589775433.html
Veröffentlicht : 09/06/2020 8:53 am
Olivier Le Mô
(@olivier-le-mo)
Bonjour ! J'ai acheté un raspberry pi zero W tout court, sans GPIO soudé comme dans le tuto.
J'ai oublié de commander les connecteurs de 18mm de haut et je n'en trouve nulle part sur aliexpress, savez-vous où on peut en trouver ?
Merci d'avance !
Veröffentlicht : 05/11/2020 6:02 pm
aln.perez
(@aln-perez)
là peut être...
j'y ai commandé les miens en 19mm et c'est ok
MK3S + MMU2 migrée vers une MK4 +MMU3 , puis vers MK4S MMU3, puis upgrade vers Core One, Elegoo Mars, bricole sur Home assistant, arduino, 8266, Esp32, kicad, Freecad et Fusion 360
Veröffentlicht : 05/11/2020 7:17 pm
Olivier Le Mô
(@olivier-le-mo)
