Loose Heat Block After Extruder Nozzle Change
Disante Picolantus
(@disante-picolantus)
I followed the steps in this video to replace my nozzle however after doing so my heat-block is too loose. Is there a way to easily re-tighten it without having to disassemble the entire hot-end? Thanks.
Napsal : 16/06/2023 8:48 pm
There is a better procedure here, pay particular attention to the diagrams at the bottom of the page:
https://help.prusa3d.com/en/article/changing-or-replacing-the-nozzle-mk2-5s-mk3s-mk3s_2069
Napsal : 16/06/2023 9:56 pm
Disante Picolantus
RE: Loose Heat Block After Extruder Nozzle Change
Great, thank you
Napsal : 16/06/2023 10:23 pm
