Einsey Board Dead - How to tell
Mike G.
(@mike-g-3)
Membre
Hello, I need some assistance here. Looks like my Einsey Board is fried and I'm trying to confirm that its fried and what I have to check on the printer before I fry and second one.
Everything was working 2 days ago, then I moved the printer.
1)  Did the Z step tuning
2)  Then the Printer started throwing up "Z-Level" Enforcing
       - Checked Z-step ok/ Ran z Calibration/ Ran through the Calibration
3)  Then it started throwing up "Thermal Anomaly" when the Printer was pre-heating the nozzle (huh)
4)   Ok started to do a "Wizard Level" Calibration, and it failed as Bed/Therm.. Not Connected
5)    Then i plugged the Power/Panic lean back into the Power Supply, and heard a "zit", and the Display went blank.
6)    I've ran a  volt meter on the Bed Thermocouple and Heater Leads and get resistance, so looks like they are ok
          Checked the fuses -- The are ok.
7)   I have 24v on both the power leads from the Power Supply.
I presently have the Einsey Board out and disconnected.
Any assistance is appreciated
Publié : 21/07/2023 8:38 pm
Hello
(@hello)
RE: Einsey Board Dead - How to tell
OK first of all hoe old is printer
Publié : 21/07/2023 11:22 pm
Hello
(@hello)
Second a nice clear photo of the board then download pronterface and connect only the power cables from the psu to the einsy and connect board to computer via usb attempt to connect via pronterface what happend
Publié : 21/07/2023 11:24 pm
1 personnes ont aimé
Hello
(@hello)
@mike-g-3 Also any lights turn on on the einsy
Publié : 22/07/2023 7:55 pm
Mike G.
(@mike-g-3)
Membre
Thanx for the response, the printer is an DIY MK3S+ and the board is definitely shot. Powering up the board show nothing.
So looks like a 3.9 upgrade...
Again thanx
Publié : 23/07/2023 1:26 am
Hello
(@hello)
Sorry didn't even see your post still try connect via prontoface bootloader may still be active
Publié : 01/09/2023 9:04 am
