Adding Text to printed objects
There is a feature allowing users to print textual content on 3-d printed objects - included in version 2.6.0. When I right-click on the object, menu choices do NOT include any textual insert item. I am using an Apple MacBook Pro with an M2 Max processor. Any ideas?
Publié : 10/08/2023 6:10 pm
First you have to not be in simple mode. Then you right click, choose 'Add Modifier' and then select Text. Simple as that. You can also use add part>text etc
Publié : 10/08/2023 7:31 pm
Topic starter
answered:
RE: Adding Text to printed objects
Thank you - I'd forgotten that!!!! Almost as bad as "is it plugged in". Working now 😀
Publié : 10/08/2023 9:44 pm
1 personnes ont aimé
