Adding Text to printed objects
Cookiemonster4
(@cookiemonster4)
There is a feature allowing users to print textual content on 3-d printed objects - included in version 2.6.0.   When I right-click on the object, menu choices do NOT include any textual insert item.  I am using an Apple MacBook Pro with an M2 Max processor.  Any ideas?
Posted : 10/08/2023 6:10 pm
First you have to not be in simple mode.  Then you right click, choose 'Add Modifier' and then select Text.  Simple as that.  You can also use add part>text etc
https://help.prusa3d.com/article/text-tool_399460
Posted : 10/08/2023 7:31 pm
Cookiemonster4
(@cookiemonster4)
RE: Adding Text to printed objects
Thank you - I'd forgotten that!!!! Almost as bad as "is it plugged in". Working now 😀
Posted : 10/08/2023 9:44 pm
Neophyl liked
