80 hour tune-up, printer maintenance?
Dik Harrison
(@dik-harrison)
I really love my MK3S to MK3.9 upgrade...  After 70 hours of printing, I started having bed adhesion issues so I tried using glue for the troublesome prints.  After about 80 hours of printing, I found that a print with a large flat bottom in contact with the bed had issues with the quality of its first layer.  While researching I found this post (Bed Adhesion Issues After Upgrade to 3.9 ), which led me to check the belt tensions, which were way too loose.  I printed a 75mmX75mmX0.2mm test print before and after adjusting the belts.  Now I'm happier with the upgrade...
Maybe everybody should check their belts after 50-60 hours of printing.
My printer is in an enclosure that is left open when I print PLA and left closed when I print PETG.  Since the upgrade, I have printed about 50% PLA and 50% PETG.  My print statistics are:
X-axis travel 5.3Km
Y-axis travel4.5Km
Z-axis travel 51.8m
Filament 225.9 m
time 3d 10h (82h)
Publié : 14/03/2024 7:33 pm
1 personnes ont aimé
Dik Harrison
(@dik-harrison)
RE: 80 hour tune-up, printer maintenance?
I started a print with PETG and noticed issues again with the first layer.  Had to adjust the belt tension again.  Hope this does not occur every time I switch filament type.
Publié : 16/03/2024 4:45 pm
