Help with MK3 bed level
Lynk
 Lynk
(@lynk)
anyone here running the nylock mod on their mk3s? i noticed my full bed prints showed left side of bed didn't have enough squish and checked my bed level using octo. For some reason, i can't get this to be at 0 baseline with the nylock. What I'm also having a hard time with is getting all points as close to 0 as possible without affecting any others. Lowest i got before this run was 0.014 and then slightly rotated the right middle and it threw off all other points again. When i adjust each time, do i adjust all points or just those that are too high/low unless pretty close to 0?
I just replace my y carriage and bed as i thought it was warped following my headaches getting this thing level just to be encountering the same with the new...pretty sure i'm not doing this right.
Also to note, i removed the nylock last night, replaced the spacers and had nowhere near a level bed as top left was way up.
Both pics don't make sense to me with the values and depiction showing its above 0.
Could this happen from unlevel frame? i assembled on level surface few years ago.
Questa discussione è stata modificata 3 years fa da Lynk
Postato : 27/08/2023 12:07 am
Lynk
 Lynk
(@lynk)
RE: Help with MK3 bed level
maybe manual mesh bed leveling will fix?
Postato : 27/08/2023 2:11 am
