Y-Axis Not Working
jcstanzy
(@jcstanzy)
Y-Axis Not Working
I just upgraded to the MK2 and tried to auto home and the x-axis worked but when it got to the y-axis part the y-axis would not move. So I tried to move the y-axis through settings and it was not moving smoothly. It was very bumpy and would only go a couple centimeters. I have double checked the wiring and that isn't the problem I don't think.
Here are the links to the videos of trying to auto home and move the y-axis.
https://drive.google.com/open?id=0B2pPc2svBawwSDdMOEFhd25jTkU
https://drive.google.com/open?id=0B2pPc2svBawwSVp3WjhaNV9DRTA
Respondido : 28/06/2016 6:30 pm
Nicolas
(@nicolas-6)
Re: Y-Axis Not Working
Is the bed moving freely by hand (power off) ?
If not try to remove the belt and find if the resistance is from the motor or the bed assembly.
You can also try to move Y axis like in your second video but without the belt.
if the motor is not working even without the belt, its an electronic problem, else it's more likely mechanical.
Respondido : 28/06/2016 6:44 pm
jcstanzy
(@jcstanzy)
Thanks! I will try that.
Respondido : 28/06/2016 8:44 pm
jcstanzy
(@jcstanzy)
Turns out I just had a faulty y-axis motor.
Respondido : 29/06/2016 10:08 pm
