Y-axis endstop not working
Carlos Echenique
(@carlos-echenique)
The Y-axis endstaop has stopped working on my one month old Mk2s. If I home the bed, it starts chattering when the endstop should kick in. I have already done the following:
  • Pushed the bed back and listend to see if it engages the endstop with a click,
  • Pulled the endstop wire from the RamBo board and tested continuity. It works.
  • Flashed the firmware. No change.
  • Sent an email to [email protected] detailing all of the above.
  • Any suggestions?
    Carlos Echenique
    ce.photography
    Prusa i3 MK2s + Prusa Core One (INDX Coming Soonâ„¢)
    Publié : 20/06/2017 4:04 am
    jack.f3
    (@jack-f3)
    Re: Y-axis endstop not working
    I had the same issue.
    On my printer the printed piece that holds the button that engages the endstop broke.
    I don't know why it broke, but you can download the files from the main prusa website and reprint the broken part.
    Publié : 20/06/2017 6:24 am
    Carlos Echenique
    (@carlos-echenique)
    I checked that Jack and mine is fine. In fact, I pressed the switch down with my finger and ran an M119 command and it reported the switch as open.
    Carlos Echenique
    ce.photography
    Publié : 20/06/2017 6:53 am
